Old 03-22-2013, 07:15 PM
restore49 restore49 is offline
Test Run - chute hit nose when up - likely narrow frame conversion where my nose leans out not back. Cut the entire system from housing and fabricated a 4 link lift ( reused the original bottom lift link ). Now it lifts straight up not tilting back clearance good but a little concerned PTO shaft is only engaging 1 in. of spline where before 1 3/4 in.?? (Totally collapsed 2 1/8 in.)
Old 03-23-2013, 01:17 PM
Looks good!
Old 03-23-2013, 03:39 PM
Can you post a pic of the drive shaft? If it's a fabricated style you can probably have it re tubed at a drive shaft shop.
Old 03-23-2013, 06:55 PM
Thanks - In early attempt to correct chute hitting , lengthened original bottom lift link 1 1/2 in.. Cut re-welded back to original length shaft now engaged properly. If anyone does this conversion can supply all measurements. Next will be paint
