Go Back   Only Cub Cadets > Resources > Cub Cadet Parts Sources
Closed Thread
Old 10-28-2012, 07:00 PM
Default Parts by Jeff-sleeve hitch, PTO buttons and custom parts
I make a large variety of parts for Cub Cadets. I can make custom parts too. All parts are made by myself, I'm a machinist / fabricator with over thirty years experience.
Please contact me by: PM or E-mail at: JRDerstine@gmail.com
Heavy duty sleeve hitch adapter with two drilled lifting straps or two slotted lifting straps
$110 plus shipping
$125 plus shipping with one set of drilled and one set of slotted straps
Add a Lift Pin for an additional $10
triple drilled lift pin for an additional $15
Extended length to clear tiller mount add $5
I can make these custom length if needed.
Lift Pin for rear lift casting, double hole. I drill these so they can be positioned with the holes vertical or horizontal. They are secured with a 3/16" cotter pin and also have a cotter pin where it goes thru the casting.
$17 plus shipping
triple drilled long length available too
Height adjuster Knob for 1/1A/2A tillers using 1/2-13 threaded rod. Has correct milled radius on bottom to match rear lift pin.
$18 plus shipping
1/2-13NC threaded rod for use with above knob ( or factory knob )
$6 plus shipping
Brass PTO button
$5.50 each plus shipping
Pair of "frankenstein" bolt and nuts for WF rear lifts
$30 plus shipping
Pair of straps for the front of the QA mounts. No more fumbling with bolts,nuts and washers. Slide these in the hole and secure with a 1/2-13NC in the factory welded nut inside the frame.
$12 plus shipping
Solid Motor Mounts for QL & WF tractors, with washers, Grade 8 flanged bolts and nylock nuts.
$40 plus shipping for set of four.
Headlight rings for 1X2/1X3/1X4/1X5
$32 per pair plus shipping
See later posts for original lift pin and QA36 / QA42 / QA36A / QA42A belt tensioner adjustment parts
If you order more than one item, I will do my best to keep shipping costs as low as possible.
All parts manufactured by me and mailed from the Palm,PA post office
Please either PM or email me
Thanks
Jeff
Old 03-29-2013, 08:10 PM
90° Gear Box Shafts for tillers and snow throwers. Made from 3/4" diameter 4140 P alloy steel ( turned ,ground and polished ) with on size keyways and snap ring grooves cut.
$48 each or $92 for the pair plus shipping
If you have a "BB" angle drive gear box, I can make those shafts if you send me the shaft to copy ( it will be returned if wanted )
Just found out there are two different lengths of the short shaft in the 90* gear box. One ( as pictured above ) at 4-21/64" long and the other at 4-1/8" long.
Just let me know which one you want.
Two more different lengths. Top on is 5-15/16" long and the bottom is 4-9/64" long
Transfer shaft for the QA snow throwers. $32 plus shipping or $30 with either ( or both ) of the above 90* gear box shafts
PTO pulley puller
The pulley puller uses the 5/16" threaded holes in the pulley to pull it off much easier.
Each unit is supplied with handle and threaded rod with centering point to locate on the crankshaft. Use a 9/16" wrench or socket.
It's used as shown here ( version shown in pictures does not have the weld cutouts, all pullers have that now)
$22 each plus shipping
Ross steering box adjustment screw (Cam Follower)
$8 plus shipping
Old 01-07-2014, 02:53 PM
Adjustable length Lift Bar for front mounted implements. Adjust range of just under 28" to over 32" ( can make custom length if needed )
$35 plus shipping
NF Lift Bracket for front mounted blade
$30 plus shipping
Lift Bracket for either hydraulic lift or electric lift. This is the cut down version of the manual style.
$17 for the drilled , $20 for the slotted plus shipping
Receiver Hitch for the 82 series tractors. It bolts to the upright frame in the back.
$50 plus shipping
Old 01-19-2014, 11:41 AM
Original style Lift Pin
$22 plus shipping
Tensioner Bolt for QA36 / QA 42 / QA36A / QA42A belt with castle nut & plate button . This style has a welded nut in the end for use with 3/4" wrench. ( original style will offered later after I bend up handles)
These are 1/2 -13 LEFT HAND thread
I'll also sell just the bolt and castle nut too
Complete unit as shown $30 plus shipping
Adjustment bolt with castle nut $17 plus shipping
Plate button $17 plus shipping
Old 02-23-2014, 06:12 PM
Attachment Brackets for lift handle, both NF & WF.
$22 plus shipping
Wide Frame rear lift attachment bracket also $22 plus shipping
Old 03-23-2014, 09:12 PM
Driveshafts now being offered
Made from 4140 alloy steel
Prices are $45 plus shipping for welded flange style
and $30 plus shipping for drilled only.
Driveshaft Couplers
for 5/8" driveshaft to creeper gearbox or manual transmission.
$25 plus shipping ( if purchased with a driveshaft, $20 )
Drive Hubs - $45 plus shipping. One piece design for added strength
Old 08-03-2014, 07:20 PM
Rear Lift Pin - Triple drilled pin for rear lift casting. I drill these so they can be positioned with the holes vertical or horizontal. They are secured with a 3/16" cotter pin and also have a cotter pin where it goes thru the casting.
$22 plus shipping
( $17 with sleeve hitch adapter order )
Old 10-01-2014, 08:12 PM
Transfer Shaft for the QA snow throwers. $32 plus shipping or $30 with either ( or both ) of the 90* gear box shafts
Old 08-24-2015, 06:21 PM
Thumbs up
Thank you again Jeff in PA. Highly recommend asking Jeff to make some odd ball stuff that you may need as he just sent me a wide frame creeper handle and steer axle pin and bushings for my 108 project. Top knotch quality, fitment, etc. thanks Jeff
Old 09-07-2015, 06:20 PM
Creeper handle - $35 plus shipping
WF shown -- Will make narrow frame long ( tall tunnel )as shown for same price. If you want short tunnel handle with extension, $43 plus shipping for both. $10 for just the extension
Creeper Poppet Indent Lever - $15 each plus shipping
Brake Pivots for NF manual trans
Large pin, small pin & hex head adjustment bolt $25 plus shipping
Axle Pins for NF & WF - $15 plus shipping
Closed Thread
