Old 04-01-2013, 09:46 AM
leonmathis leonmathis is offline
Default 1860 engine mount spacers
I've just finished rebuilding my 18 hp Kohler and noticed two of the engine spacers missing from the rear of the engine (flywheel end) so I replaced them and the drive shaft is misaligned now do to the bushings. I could have lost them from a previous time when the bolts came loose. Does any one know whether or not they're suppose to be there. It also has the flywheel shield forced into the shield that is in between the engine and tractor.Thanks Leon
Old 04-01-2013, 10:41 AM
Leon
You need them if not the engine will sit on a slope and throw off the drive line. You can contact one of the site sponsors or try and machine one or use washers to space it out to the correct thickness.
Old 04-01-2013, 11:00 AM
Old 04-01-2013, 11:11 AM
Cub parts calls for 4 spacers part # 950-3009 @ $6.33 ea.
Old 04-01-2013, 01:55 PM
Is the ideal to get the best alignment with the shaft cause I have them in and I'm sure it would be better without them.
Old 04-01-2013, 01:58 PM
They were shipped from the factory with them so I would put them back in there but it's your cub and you can do as you wish.
Old 04-01-2013, 02:55 PM
Does anyone know what the purpose of the spacers are, because if it is shaft alignment they missed terribly.
Old 04-01-2013, 03:11 PM
Do you have all 4 spacers in or just 2? If you have all 4 in place the blower shroud should clear with no problem and the drive shaft should be pretty straight.
Old 04-01-2013, 03:25 PM
Yes all 4 spacers are in and blower shroud is against the shield and shaft is at an angle
Old 04-01-2013, 03:42 PM
Can you post a couple pics? Something is wrong. I need to see a pic of the engine plate and how it is sitting in the frame.
