I again have a couple questions, How do you check the power steering fluid on a 2182 ? And I read but cant find that the plastic on these models can be replaced with tin from another model. What models should I look for and is this a bolt on deal. Again thanks for all your advice.
power steering is powered by the hydro so check the rear end fluid. as the other i don't know what will fit.
Yup, the power steering is run off the hydro, as far as a a bolt on tin swap...it's not going to happen, a great deal of work would be required to put 82 series tin on one even though the frame is the same, especially with the rear mounted radiator on the 2182.
