Old 04-22-2013, 08:47 AM
timbo2's Avatar
timbo2 timbo2 is offline
Default testing Ignition coil command CH22s
Hello -
I did some basic testing on my 2284 which has never run right/starts hard.
I'm focusing on the Ignition modules at this point and tested the resistance on the spark plug lead to ground:
left side - 10k ohms - in spec
right side - 191k ohms - way high if I did it right
The manual spec says 8k-40k ohms range for that coil.
before I remove shroud and test the other tabs on the coils I wanted to make sure all the resistance readings should be done with black lead on meter going to ground.
Thanks,
- Tim
Old 04-22-2013, 09:09 AM
When testing or checking resistance, it doesn't matter which meter lead is used on a particular end of a load. Just make sure the Meter Lead has a good connection to the load.
Old 04-22-2013, 09:15 AM
timbo2's Avatar
Thanks Roland-
Just verifying that one lead goes to ground and the other to various tabs and plug lead on coil depending on test.
- Tim
