Old 04-22-2013, 12:16 PM
64ozwaterclub 64ozwaterclub is offline
Default Cub Cadet 71 Tips and Tricks to Make it Run
My new to me 71 Cub Cadet has been sitting in storage for 5 months. It ran before it was parked. What do I need to do to before I try and start it up? I am new to Cub Cadets and garden tractors.
Thanks,
Kyle
Old 04-22-2013, 12:50 PM
Dane in PA Dane in PA is offline
Thanks,
Kyle
Fresh gas, new oil, a new filter wouldnt hurt either. A little Seafoam, too maybe.
Old 04-22-2013, 01:38 PM
jmroy's Avatar
jmroy jmroy is offline
Try turning the key, 5 months isn't that long.
Web Developer - Need a website? Contact me.
Old 04-22-2013, 01:53 PM
sawdustdad's Avatar
x2. That's all I do after 5 months. Usually works unless the battery's gone dead. Then it's just a jump start.
Old 04-22-2013, 10:29 PM
I wouldn't, as he doesn't know the last time the oil was changed, or anything like that. I always do that, even if they say they just changed it. I don't trust anyone.
Old 04-22-2013, 10:53 PM
jmroy's Avatar
He's talking about starting it up, not regular maintenance. Unless it's wicked dark its probably fine to run anyway.
Old 04-22-2013, 11:13 PM
Yeah, I would put a hot battery in it and fire it up... Find out what you've got, then take care of your maintenance.
Old 04-23-2013, 12:07 AM
Darrell Darrell is offline
That is a good idea if you heard the tractor run when trying to buy it , but unless the oil looked like sludge before starting it , why change it and it turns out something is wrong with the engine. That would be oil wasted.
Just my .02 !!!
Old 04-23-2013, 05:03 AM
Grampie Grampie is offline
If the oil level is ok, start it, let it warm up,(mix all that dirty oil & sediment off the bottom of the oil pan ) shut it off then drain the dirty oil out. At the same time your burning any old gas that may have been left in the tank & carb. Also before you start the engine, you may want to add a little gumout or seafoam to the gas tank to help clean the fuel system while your running it too! Sorry, I just thought of this, Pull the spark plug and look at it before you do anything. It'll tell you alot about the engine condition before you even try to crank it over. Good Luck!
Old 04-23-2013, 09:10 AM
I always change the oil first, and just check it for debris. I started a K-181 that was on a WH without first changing the oil, and it seized. Found out that there were lots of shavings from the cylinder wall in the oil, and I'm guessing they had something to do with it.
