Old 04-28-2013, 06:53 PM
mernestm mernestm is offline
Default 2135 with new battery won't turnover
I replaced the battery on my 2135 and it will not turnover and looks like it is not getting any power since the dash gauge lights and headlamps don't come on either. I thought it might be the key switch. Any ideas how to test?
Thanks!
Old 04-28-2013, 07:05 PM
Did you check the FUSE...???
Old 04-29-2013, 06:06 PM
Default Fuse was blown
The fuse was blown, but when I replaced it it blew again.
Old 04-29-2013, 06:44 PM
Looks like it is time to investigate.
Old 04-29-2013, 06:45 PM
Well it sounds like you have a short, start looking for a bare wire.
Old 04-29-2013, 06:54 PM
After looking at a 2135 Wiring Diagram, I would look at the Ignition Switch first. It has a ground lug (Green Wire) and if it isn't breaking away from ground to start.....you will blow fuses all day long.
