Old 04-04-2013, 09:25 PM
Originally Posted by Grampie View Post
The other hole is for the rear PTO switch on the 982 series
Yep, and that hole is also for the light switch on the smokers.
Old 04-29-2013, 08:58 PM
mlhsierra99 mlhsierra99 is offline
done a little more work on the 682. put quite a few more hours on it and i must say its running sweet! love that kt17.
biggest annoyance is when it sits, takes forever to get it running. it will fire and run straight away but from what i can work out needle is getting stuck in seat and not letting more gas in. i didnt put a kit in the carb, just carefully removed gaskets and soaked it in carb cleaner. there was a large spring under the float that keeps a certain amount of tension on the float, but i think its doing more harm than good. i need to remove it and see if it fixes the problem. fuel pump works fine and i disconnected the fuel line and put some air pressure in the line toward the carb and i could hear the needle 'break' loose, so im thinking that spring is a no good thing here. its a walbro carb.
heres a pic of the front now after getting a decent upper grill and some lights in it. still need to fix the lower, looks like a truck ran over it a few times and then was put back.......
the lights run all the time the ignition is on, did the 682 originally have an extra position on the ignition switch for lights on and off while running etc? i dont see a light switch anywhere.....
also just realized that the side panels were on in this pic as well, picked them up about a month ago. now i really need to repaint the tractor so its all red......
Old 04-29-2013, 09:15 PM
Looking good!
Old 04-29-2013, 10:21 PM
Your 682 is looking good!
