Old 05-01-2013, 08:33 PM
105_Tom's Avatar
105_Tom 105_Tom is offline
Default 125 Hydro Lift Day
I finally got around to installing the hydro lift and rockshaft on my 125. I was able to use oven cleaner on the pump and brackets to strip the puke-yellow that a PO had brush painted on it at some point. The old yellow underneath is close enough to the tractor's old paint for me. I like 'em original and with their battle scars or beauty marks, whichever you prefer.
The install went smooth, no broken bolts or frame issues. I pulled the motor and cleaned the 45 years of crud out of the frame rails and checked over everything that was exposed. A PO had run the wiring harness through the S/G mount, so I had to disconnect and fish the VR and headlight leads back through the slot. The wiring harness may not be original, but I had enough flex to make it work with the hydro pump. I did add a grass screen off a parts K241 while I was in there. Did a test-fit and lined everything up and then put the screws and bolts to it. It's a project that had been on the to-do list for a long time! Now I'll have to find time to edit my signature!
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 05-01-2013, 08:47 PM
I like IT!!!
The 125 is my favorite.
Up to 534 and counting...
Old 05-01-2013, 08:55 PM
Nice job, beats the arm strong method.
Old 05-01-2013, 09:16 PM
I agree; the 125 is my favorite also. I've never liked how the engine has to be removed to install a belt on the hydraulic pump. Yours looks great!
Old 05-01-2013, 09:42 PM
Nice install Tom!
Old 05-01-2013, 10:00 PM
Great job, Tom! Now you can lift your implements with ease!
Old 05-01-2013, 11:56 PM
cadzag72 cadzag72 is offline
Nice! That's an upgrade I'm hoping to do with my 125 at some point. I haven't decided whether to do a stock setup or fabricate something, but I do like the look of the stock setup. well done!
Ian
Old 05-02-2013, 12:16 AM
Nice job, looks like it belongs there
Old 05-02-2013, 11:33 AM
Great job and pics! I love those NF hydraulic lifts.
Old 05-03-2013, 05:13 PM
Donovan M.'s Avatar
Looks good. I should get one so kids can stop asking me why my right arm is stronger than my left.
Donovan:
62' Original-fenders
