Old 05-14-2013, 03:38 PM
dimage dimage is offline
Default 2166 blowing fuse
2166 will start but will blow the 25amp ignition fuse in about 5-10 seconds
Old 05-15-2013, 12:10 AM
You have a short. You will just have to trace the wires and look for it. It is probably a wire rubbing on metal some where.
Old 05-15-2013, 10:00 AM
Thanks, in searching the web last nite that was the general verdict. Time to trace wires. Thanks again
Old 05-15-2013, 11:24 AM
Let us know what you find out.
and
Old 05-28-2013, 01:28 PM
Just a followup. PTO clutch was shot at the same time, tried isolate wire problem, disconnected wiring to pto switch and clutch, and reconnected inserted new fuse and has worked fine since, then replaced pto clutch thanks for the help.
Still not sure why fuses blew but mowing happily again
Old 05-28-2013, 01:33 PM
Glad you're mowing again!
