Old 06-11-2013, 10:31 PM
inspectorudy's Avatar
I have mowed with several larger tractors using bush type decks and many smaller mowers including the walk behind and if the grass is too high they all leave an uneven cut. I think the secret is to not let the grass get too high.
1811 Hydro
Old 06-11-2013, 10:36 PM
Tall grass killing device
Old 06-11-2013, 11:02 PM
rweaver rweaver is offline
I get to use all kinds of decks to mow with I think the biggest thing is getting them setup right 1st is not level like most guys will tell you its best to have 1/4in nose drop that way you are not getting any recutting on the back side of blade 2nd is sharp blades as far as which deck I like the best is I like the newer 48 54 gt decks they just power thru the high stuff the other thing is with the gt decks lots of times they are running 20hp +
Old 06-12-2013, 09:00 AM
SGragg SGragg is offline
Inactive Member
Thanks for all the comments. They're appreciated.
...and don't let the grass get so long
Remember, it was my neighbor's yard...I don't let my grass get that tall.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 06-12-2013, 10:15 AM
Berwil's Avatar
Berwil Berwil is offline
If you guys are getting lines with sharp blades and the deck down, I would look at your blades, how ground down are they? Mowing grass for my dads business as a kid, once they were sharpened within a 1/2" or so of the wing, they got retired from residential duty. There just isn't enough blade left to create lift for a nice cut. We always saved those blades for fields or lots where we knew we were going to hit hidden rocks, no loss when you bend one of those blades.
AJ, I had an issue with the 44A on my 1450 last year, the deck would hang 1/2" lower on the right side because the deck hanger bracket on the tractor and rear deck pins had so much slop in them. And since the deck is heavier on the right side it would droop, had to hold it up with a bungee to get a level cut lol. This spring I drilled out all the holes, welded in bushings and replaced worn out pins and it hangs perfect. I have a feeling that your 42 has worn out pins/holes, its just balanced so it hangs level till you hit a side hill and then it tips.
Old 06-14-2013, 06:12 PM
I did the same thing with my 44C but I just used thick washers and welded them to the upper part of the hole so that they were in the same place that they started from at the factory. It took all of the slop out right away.
1811 Hydro
