Old 06-16-2013, 11:12 AM
brennanpersonal brennanpersonal is offline
Default Drain Plug Size?
I have a 10hp 108. I want to add a Fumo quick drain plug. It has a hose attachment to make this messy process a lot less messy. To order it I need to know the side of the plug.
Thanks.
Old 06-16-2013, 11:23 AM
Grampie Grampie is offline
Not knowing what any of the previous owners may have done to your tractor, I would pull the drain plug and measure the threds to be sure so you get the right part.
Old 06-16-2013, 11:27 AM
It is original. Would rather just order the correct size in front of a change. But, thank you. I do believe it is 3/8.
Old 06-16-2013, 12:07 PM
PaulS's Avatar
PaulS PaulS is offline
For the most part Kohler engines use a standard pipe plug. If your plug has a square head that is most likely what it is. If I recall correctly it has what they call NPT threads and is for use in 1/2 inch pipe. NPT is National Pipe Thread and is quite common.
Old 06-16-2013, 12:21 PM
Very Nice Looking Tractor! Original, OK, 40 years old, OK. I think I'd waist a quart of oil over the price of a Fumo quick drain plug to make sure I was ordering the right part in the first place. I understand trying to SAVE A BUCK but I can't see anyone, Taking a Guess 1/4"NPT, DON'T BELIEVE EVERYTHING YOU READ ON THE INTERNET.
Old 06-16-2013, 12:27 PM
There you go! What is it? 1/4", 3/8", or 1/2" ? Take it out and measure!!!
Old 06-16-2013, 12:34 PM
Wasting Mobil I, I don't think so. The Fumo has a 3/8 NPT and I am pretty sure that is what it is. The real pain in this tractor is that I have to remove a plate to get to the valve and that plate is a complete pain to get off. I may just take it off and leave it of although I am loath to do any modifying on something I spent a year bringing back to life from a dead hulk parts pile spread out over a half acre . By and By I am pretty stupid and the restoration was a very slow process. This was a touch and feel process and I don't even know how to measure thread so that should give some indication from where I have begun. You should have ben around when I was taking apart the rear end and the motor. "hey Annie, what do you think this metal thing is? I think it's made out of iron or something"
Old 06-16-2013, 06:44 PM
......OMG ..... well, at least it runs. If it's that big of a pain, why bother? Is it really that big of a deal to pull a plug? Never really bothered me....
Old 06-16-2013, 06:52 PM
I bent a piece of sheet metal to put the drain oil where I wanted it.
Old 06-16-2013, 07:53 PM
Since alternate ideas are coming up...
I cut the top off of a 7.62x54R ammo "spam can" to use as a drain pan for cubs. It works awesome. It slips in between the deck and the motor, but I usually change the oil with the deck off anyhow. For me, it's only 1-2 times a year anyhow.
A cut down gatorade/milk/whatever jug also works well (if changing cold oil). The ammo can is a metal version and is good for hot changes. I would think a cookie tin or anything that fits in there would be fine and should cost way less than $30 for the fumoto.
But... If you have your heart set on it, there are 2 ways to determine thread size... Pull the plug, take it to the hardware store and see what mating thread fits it, or use a thread gauge. I recommend option 1 since it's free if you don't have a thread gauge.
