Old 06-11-2013, 11:20 AM
Your making good progress! Keep the pics coming!
Old 06-11-2013, 08:11 PM
sareed sareed is offline
Im loving that red paint. Like Archie McCardell once said "all IH tractors should be RED! (thus the red 82 series was born) Never too late to go a little crazier and make it look like an IH 1066 Hydro! With the red paint on the 149 frame, it looks kind of close.
Job well done!
Scott
Old 06-12-2013, 08:37 AM
sawdustdad's Avatar
Thanks for the suggestion, Scott. The 1066 Hydro is actually the look I'm going for. It's a beautiful tractor, isn't it?
Old 06-12-2013, 02:58 PM
That is one sweet tractor! This should be an awesome project. I got a local guy that can do the decals if you need them. You may intrigue me to want to start another project! Fathers day gift maybe? I would just have to get the wife's blessing, which is never easy! lol
Hope i can be of help!
Scott
Old 06-17-2013, 07:31 AM
sawdustdad's Avatar
A little more progress. front axle and steering links installed last night. Plus, I got a present in the mail.
I discovered that the rear wheels were 7 inch rims even though they had 23 x 10.50 tires on them. Will need to pick up a pair of 8 inch rims. At this point I am waiting on brake pads to finish up the rear end and I still need to fix the manual lift arm. I have some testing to do on a hydraulic lift idea, so that might eliminate the lift arm issue. Not sure yet.
Old 06-17-2013, 08:02 AM
Looking good and nice present!
Old 06-17-2013, 11:33 AM
Looking good! Like the present!
Old 06-19-2013, 10:00 AM
sawdustdad's Avatar
more progress on one front, disappointment on another...
Got the brakes on, and extended the creeper handle to fit the wide frame tunnel cover. (Will apply the decal to the tunnel cover)
Still struggling with the lift arm. Cut off the bottom of the "J" yet was unable to drive the rod up through the arm. I think it doesn't go that way. Looks like it's coming off the tractor. Time to get out the solid carbide twist drills.
Old 06-19-2013, 01:33 PM
wow ,you do good work, and fast too, nice paint, that handle is bent, and looks very long but fits prefect, loaded with options too, where did u get all the otions
Old 06-19-2013, 09:38 PM
sawdustdad's Avatar
Yes, the handle is bent. and extended. I did this to get the NF creeper to fit this WF. It is a little bit longer than usual, I think, but actually easier to operate as a result. Maybe a little unconventional, but certainly functional and with the tunnel cover on, nobody knows.
The options were sourced from ebay, forum sponsors, and forum members.
