Old 06-17-2013, 04:59 PM
Peruvian Peruvian is offline
Default Cutting grill to install headlights
I ran my 1250 into a bush while mowing last weekend and the headlight grill bent and broke. Luckily I have a spare but it doesn't have holes for the headlights. I used the old one to draw out where the lights go, but I'm not sure how to cut the perforated metal as tin snips are too large to get a start and a wire cutter it's working.
Any ideas short of having a friend use a acetylene torch?
Old 06-17-2013, 05:00 PM
Hole saw... Or buy a panel with the holes. They're usually not very expensive (probably less than the cost of a hole saw).
Old 06-17-2013, 05:21 PM
cubby102's Avatar
cubby102 cubby102 is offline
I used a dremel when I made the one for my old 1650
Old 06-17-2013, 05:42 PM
IHinIN IHinIN is offline
Cutoff wheel in a die grinder or Dremel. Hole saw would probably grab really bad.
Old 06-17-2013, 05:48 PM
Then run it backward at first after getting your pilot hole started to create a smooth channel, then go forward, slowly, to do the real cutting. Some oil would probably help too...
Old 06-17-2013, 06:36 PM
I wouldn't recommend that. You'd tear up the panel trying. I'd just look for a used one, they're pretty cheap. Or, the dremel idea is pretty good. Here's a third idea, take it to a welding shop with a track plasma cutter. It will look good and be perfectly round. Shouldn't cost too much..... at least at the welding shop I use it wouldn't.
Old 06-17-2013, 06:46 PM
That's probably the best solution if a replacement can't be found.
Other techniques are probably up to the person... I'd screw it up hardcore with a dremel, but that's just me!
Old 06-17-2013, 07:27 PM
Thanks for the advice. If anyone has a spare headlight panel for a QL, let me know. Otherwise I'll try the local welding shop.
Old 06-17-2013, 07:39 PM
One other possibility is if you know an electrician they may have a hole punch the right size. Greenlee makes punches that will do what you need but I don’t know if they make the correct size.
Old 06-17-2013, 07:49 PM
It's a bit salty, but partstree has them, new, for $55+shipping...
They call it out as IH-61419-C2.
Personally, I would troll ePay and craigslist and wait for something to pop up. I bought an entire 1200 sans engine for $50 on CL.
