Bump.
All these cubs being fixed up there should be many people posting! Lol
882 diesel, x3 ih 582, 73 124, x2 82 seriers pullers, 1686 16hp puller |
I have a Harbor Freight cabinet and a 60 gal compressor. I use garnet sand in it.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
I bought a sand blaster at Sears for about 70 dollars. My compressor set up is a 5 horse 220 compressor with a 15 gal tank hooked to a 80 gal tank. The blaster works pretty good but after trying electrolysis to remove paint and rust the sand blaster just sits there looking dejected. Electrolysis takes longer but without the dust and mess of sandblasting.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
I use a 3500 psi power washer with a sandblaster kit. If the part is real rusty I will use sandblasting media, If its just surface rust the play sand works well for me. One thing to remember with play sand is to open the bag and let it dry, Because moisture will clog the nozzle. You do get wet but on a hot day its fun and cool, and no dust to breath in. Yes it will start to rust because of using water but time and a wire wheel shines it right up. I got some rims to do in a couple of weeks, If I remember I will take some photos of them.
I'm shocked that no one where has the "big" harbor freight cabinet (40lb cab)! My Dad has one and it works shockingly well.. It's JUST big enough to get an inline 6 (258) oil pan in. It would be almost perfect for a cub hood if you don't mind opening the door to flip it around. For $200 it's a criminal steal. His compressor is some ancient thing from 1953 (honestly) that has been piston slapping for at least the past 20 years.
I have no idea what media he has, but I'm betting its not much better than play sand. When I have a job that allows me access to a cabinet, they are usually using a coarse aluminum oxide media. No matter what blaster or media you're using, hitting your part with a wire wheel on an angle grinder before blasting will save you at least 1/2 the time. |
Played with the pressure washer sandblaster today on the dump bed for my Deere Dumper. Got most of the nasty stuff off before I ran out of sand. Before and after pics. I like this tool!
Sam, your garage always looks absolutely spotless.
Always impressed !
Joe 1200 Puller[/U][/B] 1864 2072 with 54 Inch Haban Blade |
... are those 2 1" cylinders on that dumper? I think the bed needs bigger (3140lbs/ea @ 1000psi)!!! ![]() Quote:
He's cheating!!!
