Old 06-15-2013, 06:46 PM
The 2166 has a fuel shut off solenoid the needs power to run and it may have a Spark Advance Module that also needs power so unless you had it wide open when you unhooked the battery I would guess it would shut off.
Old 06-18-2013, 02:00 PM
Ray469 Ray469 is offline
Ok, after getting the battery charged at Autozone, we finally had a decent weather day. Mower ran fine till it ran out of gas (about 45mins runtime). I stopped for a phone call about 20 mins or so after that. When I went to start, the motor would barely crank at all, and then went to nothing, no turn over, nothing. It has been raining since, so I have not had a chance to check battery again. I am assuming battery is dead again though, since engine would not even turn over, after it barely cranking just before that. Does this mean alternator, or is there another possible cause?
Old 06-18-2013, 04:02 PM
Sounds like you have one of two issues, 1 it's not charging or 2 you have something drawing more juice than the alternator can produce. Time to get out the meter and find out what the problem is.
Tags
2166, battery, pto
