Old 06-18-2013, 10:47 PM
livnlife livnlife is offline
Default hello all
It's the first time here, so sorry if I'm a bit vague and unsure. I have a cub cadet 1810, the best mower I have ever owned. I cut approx 2.5 acres every week until last summer. I got a hydro relief valve leak and got some reman. valves. It worked good for 1 month, .now I have no reverse. Even if I swap valves, still no reverse. I'm looking for advice as to some fixes, or is the pump had it.
Thank you
Old 06-19-2013, 06:59 AM
Welcome to OCC
I moved your post from the welcome area to the CCC MTD area so that you will get more feedback on your question.
Now onto your Hydro issue. As I read your post the tractor will only go forward, you have swapped the check valves and it made no difference. That leads me to believe that you have a linkage problem not a hydro problem.
Old 06-19-2013, 07:23 AM
Old 06-19-2013, 07:55 AM
I would agree.
Old 06-19-2013, 10:30 AM
Welcome to OCC! You've came to the right place with your cub issues!
Old 06-20-2013, 11:58 PM
cubby cubby is offline
welcome here
