Old 06-16-2013, 08:47 PM
fhadderton's Avatar
fhadderton fhadderton is offline
Default 149 motor swap
Well I finally decided to swap engines in my 149, the twin cylinder Briggs wasn't reliable so out it came. The p/o did a decent job on the install of the Briggs, they had fabricated a plate for the motor mount, and swaped the original drive line out. I cut the mount out and made a new plate for the motor I'm installing. All I have left to do is shave down the adapter I made for the drive shaft and install the new motor. I also steam cleaned the gas tank it wasn't a pretty sight, lots of gunk. The new engine is a Kohler 12hp magnum, a good friend gave it to me, he had never used it.
Old 06-18-2013, 10:44 PM
fhadderton's Avatar
Here's a video of the progress http://m.youtube.com/watch?v=LbN8rASLd0A
Old 06-18-2013, 10:45 PM
Your vid isn't working.
Old 06-18-2013, 11:49 PM
fhadderton's Avatar
I'm not sure why it wasn't working but I think it's up now
Old 06-19-2013, 08:23 PM
fhadderton's Avatar
If y'all watch the video I'm needing some wireing help I showed I can't figure out
Old 06-22-2013, 11:41 PM
fhadderton's Avatar
Got the throttle linkage done and finished up my dual adapters
Old 06-23-2013, 12:11 AM
Nice project.
But still no vid. on my end.
Old 06-23-2013, 01:36 AM
fhadderton's Avatar
I'm not sure why the video isn't working, the main question I had was on the wireing. The motor was a stand alone engine, I pulled the throttle and choke off and modified the linkage to work with the tractor. I found and hooked up the charging wire but that's it there are three wires that come out by the carb and I don't know what or where they go.
Old 06-23-2013, 01:40 AM
fhadderton's Avatar
I by the way here is the drive shaft it's a p/o mod but I'm keeping it, it was originally a drive shaft off of an international 21 cotton stripper. A u joint on bolth ends and a hex shaft.
Old 06-23-2013, 10:05 AM
Your tractor looks tough!
