Old 06-22-2013, 10:48 PM
Yep that's a good enough pic. Even though I had to tilt my head It has the IH carburetor on it. If I remember correctly, there is only one IH carb option so it should be easy. Is that what you needed to know?
Old 06-22-2013, 10:59 PM
dgrapes59 dgrapes59 is offline
It look like an IH carb (not a Zenith), get a kit from an IH dealer or from Steiner Tractor parts, don't get one from TSC or you will be sorry. It costs a little more but this is one of those things you get what you pay for.
This is a complete kit and includes the idle tube that can be expensive by itself, they have cheaper kits if you don't need the tube.
http://www.steinertractor.com/IHS825...tor-repair-kit
Be careful separating the carb, the idle tube is often broken during this procedure.
You can get a FREE replacement Safety gas cap through the following link :
http://www.tmtractor.com/new/fl/fuelcap.htm
Nice looking LoBoy!
Good luck,
David
Old 06-22-2013, 11:41 PM
Conductor562's Avatar
Conductor562 Conductor562 is offline
Thanks guys! So what model is mine? Is it a 154? I'm not real familiar with these. I believe it to be either a 67 or 68 and I know it has a C60. It needs a bunch of seals. There's hydraulic fluid leaking everywhere and there's quite a bit of oil build up along the oil pan and where the motor bolts up to the bell housing. I'll do it a little bit at a time. Still trying to finish my original as well.
62 Original: Work in progress
Check out TOOLS IN ACTION blog
Old 06-22-2013, 11:48 PM
I kept quitting on me at random times, usually on a hill or trying to run in 3rd. It ran a lot better at half choke though. I took the oil bath breather apart and there was a ton or crud built up in it. The top screen was gummed up pretty good as well, so I cleaned everything out (including the tube to the carb) and filled it up with oil. I figured I'd go ahead and clean the carb as well, but the main gasket fell apart and when I put it back together it leaked.
What type of oil is best for the breather?
Old 06-22-2013, 11:49 PM
Its an international cub lo-boy. Nothing else.
Old 06-22-2013, 11:52 PM
If it runs better with the choke on, it's running lean. IH recommended 30wt in the air breather. (Anything close to that is fine.... I.E. 10W-30.) I think it's stamped into the side housing of the oil bowl, near the fill line.
Old 06-24-2013, 12:47 AM
Ordered the carb kit and the hydraulic cylinder block seal kit from farmallparts.com. I'll get the card lined out asap so I can mow with it. The hydraulic cylinder will be done on a time permitting basis. I'd like to put all new seals in the motor, but tearing a motor down is a little more than my limited experience permits. My next purchase will be front wheel bearings. I've still got my original in pieces as well. I've got plenty to do now
