Old 06-26-2013, 09:44 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
Default Diesel and iron rear.
i picked up an iron rear last week from a 105. i decided i wanted to try it out in my 1772 since i had a few stripped bolts and this cub will be getting my backhoe put on it. so i pulled the aluminum rear out last weekend and started the tear down. i pulled all the gears out of both rears and put the super gears into the iron one. i have never set up gears before so it took me a few try's to get the shims correct but i think i have them set up pretty well. as of now i have the rear back together and ready to go back in. i know there will be some playing around with the fuel lines/tank to get the everything to fit correctly. wish me luck, ill be updating as i progress.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 06-26-2013, 10:15 PM
cubby102's Avatar
cubby102 cubby102 is offline
Lookin good
Good luck and looking forward to your updates! The aluminum rear that was in my 1872 was replaced with a cast iron one last year.
Old 06-26-2013, 10:29 PM
ken6x6's Avatar
this rear will also be coupled by Sams drive shaft. the drill and tap of the pump went smoothly. you can see the the adapter on the pump.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 06-26-2013, 11:20 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
If you have a rear PTO installed on your super, does that mean you cannot use a CI rear end on it without losing the rear PTO?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 06-27-2013, 06:08 AM
ken6x6's Avatar
the super 3 points and PTOs are different from the iron setup. i know Xtream sells a cat 0 for the iron rears. doesn't have PTO tho.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 06-27-2013, 07:16 AM
Frank
I'm pretty sure that you need the aluminum rear with the rear PTO.
Old 06-27-2013, 07:25 AM
Ken
Looking good. When you get the rear back in measure the space between the 2 adapters and I'll have the shaft welded up and send it to you. Also need to send you 3 longer bolts for the adapter for the engine, FrankF3 got some longer bolts that I like better that the 3 I sent to you. Looks like between the way Cub describes the bolt length and the way McMaster describes them I ended up with 50 bolts that are shorter than they should be.
If the fuel tank looks like it will be an issue maybe these guys can do a custom one for you http://www.boydwelding.com/shop/ or at least it will give you some ideas.
Old 06-27-2013, 09:45 AM
982's use a cast rear with pto, all you need is the CI rear cover. If you have a super, the only cat 0 to use is the Bill Ruegg hitch.
Old 06-27-2013, 12:00 PM
red56turbo's Avatar
Looks like the switchover's going smooth. Todd's right, you'll need a cover from a 982 for a rear PTO if ya want one. You'll have to let us know how the fuel tank and such fit. I was always told the cast iron rears caused a problem on super diesels due to clearance issues and the fuel tank.
Josh
Diesel Cub Cadets...........
