Old 07-02-2013, 10:56 AM
Sam Mac Sam Mac is online now
I probably should have added that my 2182 is electron challenged. You can run the PTO or the anemic factory headlights but not both at the same time. Pretty sure the electrical system was designed by Lucas the Prince of Darkness from British Car fame.
Old 07-02-2013, 12:45 PM
Old 07-02-2013, 11:33 PM
Big Red's Avatar
Big Red Big Red is offline
No, not LED. And you are correct, they usually are 15A. My engine has been replaced with a M18 and I think it must have the 20A charging system on it. I put the lights on before I knew the charging system was only supposed to be 15A. I put them on 10yrs ago, and haven't had any charging problems I have checked the charging system with all the lights and PTO on and it just does make 12V.... Like 12.3-12.6. I don't care, I like them.
Sweet! My 782 has an M18 in it. I just assumed it has a 15 amp charging system. I didn't know they were available with a 20 amp option. Now I'm wondering. I do notice that I don't have to rev the engine as high to keep the amp meter on the + side when the lights and pto are on, compared to the M14 that is in my 1430.
I had a similar light setup on my 1430 a couple of years ago. I got really creative and mounted a 105 amp GM alt. so it would run off the input shaft on the transaxle. It was a stuff job to get it in there. My drive key, which was a piece of alen wrench ended up rounding off after about a years worth of use. Back to the drawing board. It was cool while it lasted though. I could mow perfect in the pitch black of the country out here. Here is a pic.
Kevin
1981 782 "Big Red"
1993 1430 "Little Yeller"
Old 07-02-2013, 11:42 PM
Awesome! Like I said, I like my lights! I'm really busy and don't have time until evening or even night to mow. This year already I've probably mowed in the dark as much as I've mowed in the daylight. Out where I live there are NO lights. I don't even have a dusk to dawn and I have about 1.5-2 acres I mow. I actually put the lights on because I clean parking lots in the town I live in. Best time is at night when there are no cars. I usually start pushing/blowing snow at about 9, and work till midnight or later. It's pretty good $$ and winter is tough time for me to make money, so it helps!
Old 07-02-2013, 11:50 PM
Or was it Phil, The Prince of Insufficient Light
Old 07-12-2013, 11:16 AM
fourinchdragslicks fourinchdragslicks is offline
long overdue, but here are the pics of my hidden backup light
