Old 07-15-2013, 12:30 PM
jcsmith jcsmith is offline
Default 1996 K301 replacement engine
I've a '96 K301 spec 47504. I thought all K301's had the flat section on crank counter weights. Mine are round. One thick, one thin. Both valves have rotators. Style D Mahle piston. Has balance gears. Fully adjustable Walbro WHG carb A few questions.
1. Any significance to the round counterweights vs flat ?
2.Are valve rotators meant to keep seats cleaner ?
3.How long has Kohler used Mahle pistons ?
4.Has anyone kept the balance gears ?
5.Is the K301 the most out of balance single K engine ?
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 07-15-2013, 01:50 PM
Here are my answers:
I have no idea
Valve rotators are meant to rotate the valve so that it seats at a different spot each time. Not necessarily for keeping clean, they are for keeping the valve and seat sealing properly. It keeps them from wearing on one side.
I have no idea
Some people do, some don't. I prefer to.
No, 301 up has balance gears. I'd say it starts with the 301 because the bore finally got big enough that the weight of the motor rotating assembly became large enough it needed more balance help.
ANY odd number cylinder motor is "out of balance". Single cylinder, 3 cylinder, 5 cylinder.......
Old 07-15-2013, 04:51 PM
J-Mech, thanks for the response. I'm leaning toward leaving the balance gears in. It's a low hour engine in great shape. I keep reading horror stories about grenade gears wreaking havoc and destroying blocks. I just wonder if the balance gears get blamed far more than other causes. I'd bet Kohler didn't put them in just for the hell of it. Chris
Old 07-15-2013, 06:14 PM
cubfixer's Avatar
cubfixer cubfixer is offline
Flat vs. round, see this:
http://************************.com/index.htm.
Leave balance gears in? Never.
John
Old 07-15-2013, 06:37 PM
http://************************.com/balance.htm
your link doesn't work.......
Old 07-15-2013, 07:00 PM
cubfixer's Avatar
Try to google: Welcome to Brian Miller's Garden Tractor Pulling Tips & Tricks!
Then scroll to :
Balancing the crankshaft and connecting rod assembly.
Occ won't let me type the URL, sorry.
John
Old 07-15-2013, 07:09 PM
jcsmith. Is this going to be a pulling engine? Or a "working" engine? Maybe I should have asked this first......
Old 07-15-2013, 07:52 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
does your crank have a 3/8 24 grade 8 bolt holding the flywheel on or a big nut?
Old 07-15-2013, 08:46 PM
J-Mech, this is a work engine
dvogtvpe, it has a 3/8-24 grade 8 bolt
cubfixer, I'll check it out. I like his site
Thanks for the replies fellas, Chris
Old 07-15-2013, 09:45 PM
dvogtvpe's Avatar
the cranks in the magnum singles identified by the 3/8 bolt from what I've heard from pretty reliable source's are supposed to be forged vs the cast cranks of the K series. that design also has a rounded counter weight. so bottom line . its a better crank.
Valve rotators are designed to prevent burnt valves.
The Mahle pistons have been around since the mid to late 80's.
Balance gears are good for scrap in my opinion. I've seen one to many fall off I guess.
most out of balance single would be a K361 OHV followed by the K341. I think as the strokes got longer and the bore's bigger the shakes got worse. I never thought the 12's and 14's were that bad. J-Mech is right. odd number engines don't cancel themselves out
Millers site is alright. there's some useful info there for the novice, most of the info there We and allot of others were doing 20 - 30 years ago so there's better ways by todays standards . user's beware, don't take it as gospel.
