Old 07-28-2013, 02:21 PM
dieselsmoke dieselsmoke is offline
Default Diesel fuel conditioner
I'm wondering if I should be putting some diesel fuel conditioner into my 882. The D600 engine really wasn't designed to run on the ultra low sulfer fuel we have today. If so what are you guys using?
Old 07-28-2013, 02:34 PM
cubs-n-bxrs's Avatar
I use a product called K-100.
Old 07-28-2013, 02:58 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
im using power service diesel fuel supplement. i use it in all my diesels. i put it in the 1772 and with in a minute wile it was idling i had a noticeable increase in rpm. the engine seemed to perk up once the treatment got to the engine. its good to run some type of treatment helps keep everything clean and helps a lot with cold starts.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 07-28-2013, 05:23 PM
CubDieselFan's Avatar
I use Power Service too.
Old 07-28-2013, 07:10 PM
Same here. That's what I use also.
Old 07-29-2013, 01:14 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
I use a mix of Power Service and Marvel Mystery oil in my 1572 and 782D.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 07-29-2013, 01:58 AM
TheSaturnV's Avatar
I use Power Service too. Fairly inexpensive and available at auto zone and Wally World.
Old 07-29-2013, 07:12 AM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Power Service here also in both diesels.
Don Smith
Old 07-29-2013, 08:38 AM
scgtguy's Avatar
scgtguy scgtguy is offline
Default diesel fuel additive
I've been running this, Stanadyne ... these folks also build and engineer injection systems.
http://www.stanadyne.com/view.php?id=45
B.
Old 07-29-2013, 03:59 PM
cc_bob cc_bob is offline
I use off road diesel, it's cheaper and still has sulfur in it.
I like to keep em running and work them.
1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors.
