Old 07-24-2013, 06:09 PM
alabama mike's Avatar
alabama mike alabama mike is offline
Default Hydrostat question
I have a somewhat Hybrid Cub that I put together a few years ago, I bought a 582 special, 16hp briggs twin, it had a peerless transmission in it from the factory, when I got it the peerless transmission was in a box in a thousand pieces. at the time I also had a cub 1282 with a bad motor, so basicly I married the 2 together, I have built a small platform off the back of the tractor and have a 20 gallon sprayer on the back of it, I've got it set up to be able to use a spot sprayer or a spray bar with a 6 foot spray pattern. I use it around the farm and its has done an excellent job, now its starting to slow down under a load and speed up by itself, also when its off and tractor will roll if on a grade, I thought hydrostats were not supose to do that, anyway I have checked all the linkage and everything seems to be working fine, any ideas?
disabled/desert shield/storm vet, proud to have served!
582, 1782, 124 (x2), 154 LO-BOY,
Old 07-24-2013, 06:11 PM
Hydrostats will roll if on a grade and the motor is off. Try changing the fluid and filter in the machine first. A lot of times that will fix your issue.
Old 07-24-2013, 08:22 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
trunnion could be worn. or if the linkage is sloppy it could cause the trunnion to give a false response.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 07-25-2013, 12:08 AM
Try the easiest thing first. Fluid and filter change, and if that don't help it's time to get into a trunnion rebuild.
Old 07-25-2013, 02:34 AM
TheSaturnV's Avatar
Agree with these chaps, I'm also leaning towards a worn trunion.
Have a look at this one, the corners are almost worn through when they should be square. A MiG welder will fix this.
As far as rolling off the hill, as soon as the pressure in the pump lets off, the auto valves allow the machine to roll so it can be moved. Always set your parking brake.
Old 07-27-2013, 07:08 PM
thanks guys, had to order a new filter, suppose to be here monday, i'll check the truinion while I'm doing the fluid and filter change!
Old 07-30-2013, 12:24 PM
Well, did the drain and fill on the hydrostat, changed the filter, The trunion looked bad, got a hold of it with the welder and squared it back out. The bracket that fit on the trunion looked bad as well, so I had another on a bad hydro unit I put on it, now the question is what the proper way to adjust the unit, I looked in the CC manual for an 82 series tractor and couldn't find it, and I was sure if it was the same as the older tractors.
