Old 08-11-2013, 01:54 PM
oldnewt oldnewt is offline
Default starting /cranking
Hi - I'm a newbie with a 2544GT - Kohler 21 v-twin. She will start when jump started off car battery - but PTO will not engage - just getting a hissing noise. She will not start w/out jump - tested battery and get 12v+ but only 10 when running. Any thoughts? Lawn is a jungle at the moment!
thx!
Old 08-11-2013, 02:11 PM
First, welcome to OCC...
From the sounds of things you may have two issues.
(A) Charge the battery up and take it to a reputable shop and have the battery "load tested". If not good, replace battery.
(B) IF you are only getting 10 VDC at the battery when the engine is running at full throttle, you either have a bad Voltage Regulator or some sort of bad wire connection(s).
Old 08-11-2013, 02:55 PM
Default starting/cranking
Thanks - will do - trying to find voltage regulator now!
Old 08-11-2013, 04:07 PM
As a suggestion, get the battery tested so you know there is NO battery issues. BEFORE you go and buy a V/R, there is some tests to perform first.
Old 08-11-2013, 06:01 PM
thx!
Welcome to OCC!
As Roland said!
Old 08-11-2013, 06:02 PM
Welcome to OCC! Good luck with your cub.
Tags
cranking, starting
