Old 02-20-2010, 12:56 AM
rwire125 rwire125 is offline
Default repower
Hey going to pick up an 1811 tomorrow with a M-18 that I'm going to use and re-power my 782 with. Ya buddy, this will be a summer project to freshen up the mag rings and lap the valves and anything else it may need :biggrin2.gif:
Old 02-20-2010, 01:04 AM
murphycc
Guest
Posts: n/a
You'll need to swap harness and switch too, two different ignitions.
Scott
Old 02-20-2010, 07:01 AM
You can change out the wiring harness if you want to or you can make a small modification to the 782 wiring. A simply relay and a small amount of wring changes will make a M-18 work just fine in a 782.
Old 02-20-2010, 05:40 PM
got the 1811 home shes a little rough but have 75lb compression on both cyclindes so was happy about that, soo she should be good with a ring job. i just want the motor and any wiring i may need other than that not sure what to do with whats left over? ill post up some pic laiter
Old 02-20-2010, 08:22 PM
murphycc
Guest
Posts: n/a
Hood, tunnel cover, rear and pump, brakes, drive shaft, rags, side panels....etc are all worth money...grill, headlight screen.....dash.... Lots of good parts if the parts are good. Sell here, elsewhere, ebay, CL......
You may want to keep them for replacement. Nice to have a second set to paint up and decal for future repaint without losing use of the tractor for longer period of time...you get the point.
Listen, the small parts will nickle and dime you to death later so be careful of what you dispatch.
Scott
Old 02-20-2010, 08:37 PM
murphycc
Guest
Posts: n/a
rwire,
If you have an extra CCC grill emblem that's in good condition I'll buy it from you.
Scott
Old 02-21-2010, 06:52 AM
just a pic of the 1811 and murph no grill emblem sorrey also note the custom cup holder lol
Old 02-21-2010, 10:57 AM
Good luck with your 1811, rwire125!
Old 02-22-2010, 01:07 PM
got the motor pulled outa the ol 1811 pulled the heads and looks like she will need a bore job, scratches on one side look to be to deep to just hone out, im sure i can get away with .010 over but that means new pistons so maybe ill be lookin at a 19 mag when its done lol
Old 02-22-2010, 06:35 PM
FWIW,
Those cyl's/pistons show up on evil pay @ times if you are not in a hurry. Possibly that would save a bore & pistons.
