Old 08-30-2013, 12:48 PM
Default Cub Cadet 72 creeper gear install
hey guys, decided to put the creeper gear in my 72, i got the S/G off, the battery, and engine out, the frame was really dirty in there, i started to clean it out , heres some pics of progress
Old 08-30-2013, 12:49 PM
engine is out
Old 08-30-2013, 01:23 PM
Keep up the good work, Nick.
Old 08-30-2013, 01:57 PM
cubby102's Avatar
cubby102 cubby102 is offline
Your 50% there! Lookin good. Hardest part is the pins. The ones in my 124 still won't give up their rusty grip
Old 08-30-2013, 03:04 PM
exactly, i cant get them out
Old 08-30-2013, 05:33 PM
finally got them out with a 3lb hammer and punches and a 1in thick solid piece of brass, also used kroil penentrating spray oil also got the coupler off the driveshaft and clutch out of tractor the spirol pins were a PITA
Old 08-30-2013, 05:34 PM
the holes in the clutch and coupler and input shaft are very good and tight no wonder we had so much trouble getting them out, i also had to flip the tractor over
Old 08-30-2013, 05:35 PM
the clutch, where do i cut the shaft right on the score line?
Old 08-30-2013, 05:36 PM
broken pin that was in the input shaft/coupler
Old 08-31-2013, 12:12 AM
cubby102's Avatar
Yep ya cut it right on the score line be hui ind the hole.
