Old 08-25-2013, 09:26 AM
nikster's Avatar
nikster nikster is offline
Default Another use for ' PB BLASTER'
Ive had this little hang up in my throttle cable since I bought it last year. My friend Bill fixed that in about 1min..
He took my cable with a rag & blasted the entire cable with PB Blaster.
After 10min., blasted a second time with me working the throttle back & forth.
Smooth as SILK. Who would have THOUGHT?
Nik,
Old 08-25-2013, 10:20 AM
jimbob200521's Avatar
WD40 works as well too but not AS well. Glad it worked for you!
-Ryan
Old 08-25-2013, 10:45 AM
It's always good to have a can of PB Blaster around.
Old 08-25-2013, 01:58 PM
cubby102's Avatar
cubby102 cubby102 is offline
Its a little spendy but Amsoil MP (metal protector) works awesome and protects it from rusting up again. The cable on my 124 was solid when I very first got it over a year ago. Used that worked it free gave it a final spray and has been fine . And it sits outside
Old 09-01-2013, 07:25 AM
fpatd's Avatar
fpatd fpatd is offline
Even more expensive, t pull the solid wire cables out of the housing & coat them with never seize re install , clean up mess & never have a problem a gain! It's messy & time consuming but works great i learned this lesson 20 years ago , & still do it to every new cable / on every piece of equipment I get, you know what they say if its not broke don't fix it; i say if it's bran new, its a great starting point, you can almost always make it last longer & make it work better / modify for your needs at some point !
Old 09-01-2013, 12:41 PM
Once I discovered PB blaster I never buy WD40 anymore.
Old 09-01-2013, 03:28 PM
nikster's Avatar
That blaster soaks right in thru the cable. That's with a liberal amount.
NIK.
Old 09-01-2013, 11:10 PM
red56turbo's Avatar
After reading this, I used some Blaster on my sticky 782D throttle cable. Been spraying both ends liberally once a day for past 5 days. Workin' like a brand new cable. Great idea! Thanks.
Josh
Diesel Cub Cadets...........
