Old 02-24-2010, 11:23 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
Default foot controls
can anyone give me any ideas with sketches possibly on putting foot controls on a 1450? Thanks in advance.
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 02-25-2010, 01:12 AM
murphycc
Guest
Posts: n/a
This was discussed and pics were posted "elsewhere" so look around and little more. Others have done it and I want to do it sometime myself. Not as easy as you may think though but if you have the patience to fab the links and pedals and get it set up it can be done.
Scott
Old 02-25-2010, 01:22 AM
murphycc
Guest
Posts: n/a
The key to the design is to create a set of links that return to neutral since the controls on the pump are not set up to. You'll have to set up the controls to balance back to a neutral positon when you let off, spring tension in both directions will need to be just right.
Scott
