Old 09-14-2013, 02:03 PM
martin1b martin1b is offline
Default Deck pulleys are hot
I just replaced my center deck pulley and went to try it out. 2 things I noticed are 1) after a few minutes of use, the deck pulleys are pretty warm, almost hot and 2) there is sound that is new. It almost sounds like the spindles but I know they're in good shape. On the sound, I'm wondering if the deck belt is making the noise because i see it moving a fair amount, almost as if the tensioner isn't tight enough.
Thoughts on either of these?
Bill
Old 09-14-2013, 03:06 PM
rweaver rweaver is offline
1st check to see if the idler is tight that would explain the loose belt also check the idler for a rough bearing
Old 09-14-2013, 05:03 PM
Have you greased the spindles well? I would also suspect a loose belt if the belt is hot.
Old 09-14-2013, 08:45 PM
Check your mule drive pulleys also.
Up to 534 and counting...
Old 09-15-2013, 01:13 AM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
While the bearings may be good, they may be binding a bit, creating the heat. Had this happen on a JD deck - one of the bearings wasn't completely perpendicular to the spindle shaft and it made noise and got warm. Your tensioner might be too tight as well, if the wrong spring is used. Usually a belt makes noise before heat if it's slipping.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
