Old 09-01-2013, 06:59 PM
anorton anorton is offline
Default 1210 vibration
New to the forum, long time reader, first time poster. I did a search, but wasn't able to find quite what i was looking for.
My 1210 Hydro stopped on me while mowing yesterday, i was able to limp it back to the garage, with a bad vibration. I pulled the covers and it is obvious the drive shaft is causing the issue. It looks like while the driveshaft was out of shape it got into the hydro filter and put a small cut in it and the rags.
Is there a bolt of some sort that goes through the coupler and hooks it to the transmission? I have a picture if it helps. Is something missing here? If so, i think I have found the cause my vibration.
http://s291.photobucket.com/user/mr2...e0242.jpg.html
Old 09-01-2013, 07:42 PM
Well if you have a hole in the filter that would explain why it stopped moving, the hydro is sucking air. It looks like the spirol pin is missing. You need to fix or replace the worn parts on the drive shaft, replace the filter and if the fluid in the hydro is old change that also.
Old 09-02-2013, 10:45 AM
That makes perfect sense. Thanks for the response. Off to order some bearings, a filter, and a pin.
Old 09-12-2013, 09:41 PM
Angry
so i ordered what i thought was the pin, filter, and bearings. bearings are replaced and the filter is replaced, but it seems i ordered some sort of spring rather than the pin. Does anyone have a source for the part number for the pin that is missing? I have done some searching, but it doesn't seem to be listed.
Old 09-13-2013, 06:50 AM
From the Cub parts site. I know you can get these from other vendors for less.
915-3000
Spiral Spring Pin: 1/4 x 1.33. Replaces Part Numbers 715-3000, 715-3018, IH-19885-R1, IH-23670-R1
Price $2.75
Old 09-14-2013, 01:40 PM
Thanks for the help! exactly what i needed.
Old 09-16-2013, 11:11 AM
I was lucky and the cub store down the road had it in stock. The mower is going again without an issue. I love this tractor.
Old 09-16-2013, 11:48 AM
Great news!
Old 09-16-2013, 03:17 PM
Great news!
X2!
