Old 09-16-2013, 05:18 PM
Thumbs down Broke the pulling tractor
hey guys, fixed the midwest super cub clutch in my 102 pulling tractor, clutch worked great, loaded it with weight, went to the pull, and we were pulling great with pretty good traction, then at 2650lbs the rear end made a snap sound, turns out we broke the carrier, not the axles they are fine , so that wasnt a good pull, the whole rear was replaced awile ago too, everything was stock other than the clutch, so we removed the axles and broken carrier and started to wipe everything out, i am going to go with fine spline i think
Old 09-16-2013, 05:21 PM
i have a great running stock 10hp kohler in the 102, it runs out of power when the sled starts to get really heavy, i am running 23 8.50 12 carlisle power trac ag tires on the back
Old 09-16-2013, 06:36 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
stock carriers and axles don't cut it for pulling. top shafts and shift forks are not far behind.
what gear do you run that you run out of power?
Old 09-16-2013, 06:56 PM
Mainecubcadet108's Avatar
Mainecubcadet108 Mainecubcadet108 is offline
Our 10hp doesn't run out of power.It will spin before that.We only run 1st or 2nd and there stock gears and the motor only has the head shaved.And we haven't broke an axle or carrier but i'm putting a built 14hp in in the off season.And i'm putting a fine spline rear in and a hardened top shaft and all the good stuff because sooner or later it will break.
Current tractor my son and i have
1991 wheelhorse 520h 60"deck 48"snow blower w/ onan 20 hp
1980 whelhorse b-82 need restore
1976 simplicity 7116 all restored waiting for a new motor (my sons tractor)
1967 sears super 12 (my sons tractor)
1972 Cub cadet 108 restored w/ complete motor rebuild 5 years ago
Old 09-16-2013, 07:07 PM
....... ask cubcadet how much weight he has ON the tractor though....
It's the variable to the equation.
Old 09-16-2013, 07:25 PM
i had 3 weights that are 225lbs each , so 675lbs total, one was in the middle, the other 2 were on the back , a heavy counter weight of a manhole cover cut in half , 3 steel plate slabs in the middle about 25lbs each, and 25lb wheel weights on each side and really heavy wheel weights on each side , so there was about 1000lbs on it
Old 09-16-2013, 07:27 PM
We run classes 900 lbs 1100 lbs and then 1300 lbs this is with our club.Then at our local fair we pull with 1400 lbs 2 pulls.Pulling weight tranfer sled.So how much do you weight your tractor at cub.
Old 09-16-2013, 07:30 PM
Darn thats way to much if you ask me.But thats my opinion
Old 09-16-2013, 08:02 PM
I think that is why he powers out, and why the carrier broke.
Old 09-16-2013, 09:36 PM
austin8214's Avatar
I've seen stock carriers and axles break at #950. They just are not heavy duty enough for pulling applications.
