Old 09-05-2013, 01:03 PM
Tunames Tunames is offline
Default convert snowplow for 1812 to fit 2072
Has anyone tried this? Can it be done and how much trouble would it be?
Old 09-05-2013, 01:09 PM
If you are any good with metal, should be no problem.
Old 09-17-2013, 01:19 AM
Does anyone have a picture of the frame for a snowplow on a super?
Old 09-17-2013, 06:50 PM
The frame on the supers is longer, but not wider. I don't see any reason why you couldn't just lengthen the braces that run to the back. The blades for the supers were a completely different design. Looking at those wouldn't help you much. Unless you want to make a whole new sub-assembly.
Old 09-17-2013, 09:12 PM
dale c. dale c. is offline
cut the slotted ears off the back end of the blade frame and add a piece to lengthen the frame [around 4 inches if I remember correctly] and weld the ears back on wouldn't hurt to plate the frame where it is spliced to reinforce it and add a cross brace between the frame ears...
Old 09-17-2013, 10:29 PM
I set the plow under the 2072 looks like it will be an easy modification...
