Old 09-17-2013, 07:30 AM
Maple Cabin's Avatar
Maple Cabin Maple Cabin is offline
Spark (Hz) cycles per second
S = 2 for four Stroke or 1 for two Stroke
C = Cylinders per coil
60 = Seconds to Minutes
Hz X S / C X 60 = RPM
30 Hz X 2 / 1 X 60 = 3600 RPM (K series)
30 Hz X 2 / 2 X 60 = 1800 RPM (KT series)
Not to be used on magneto type coils (no low voltage connection) unless you have CT (Current Transformer) clamp. Clamped around the spark plug wire.
This works on most points/distributor system.
KT's or any opposing twins and most magneto's. No distributor but fires on both compression stroke and exhaust stroke the later is a waste but cheaper than adding a distributor system.
If you get Hz value that a too high to believe that is contact bounce but the condenser take care of that.
A little of topic
Newer automotive system with individual coils can give multiple sparks per compression stroke.
Doug
126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights
129 Deck, Blade, Weights
1200 Creeper Deck: 1250 B Tiller odd deck
782R with power steering
JD 110H:JD 112H
Old 09-19-2013, 04:49 AM
Hand_108 Hand_108 is offline
Inactive Member
Well I ordered on of those photo tachs. Waiting for it to get here. Gonna see how it works. Thanks for the heads up on that one. I would have never guessed to look for something like that.
Now I gotta ask. Where would the best place to put the reflective sticker at? On 3pt clutch driver? On drive shaft from motor to clutch? On edge of mesh that covers fly wheel? Hummm. I would think any part that is spinning at crankshaft speed would tell me.
Thanks
John
Old 09-23-2013, 08:39 PM
randallc randallc is offline
Got my photo tach in and set it up on a Farmall Cub and it seems to work great from 474 idle to 1784 open. They are suppose to idle at 500 rpms and advance to 1800. Easy to work, put in a battery, put a 1/2 inch of the reflective tape on the subject and hit the test but and read.
I don't have any other rpm method to test it on, but will take it to a CubFest and try it out to compare to someone else's.
At least I can now get an idea. My 1250 doesn't seem to crank 3600 rpms and my 109 seems to turn more. Will not open it up. My 1000 seems to be right on but will test them now with the photo tach.
Old 09-29-2013, 10:49 AM
Inactive Member
Got mine the other day and yes it was that easy!! I love it!! Got my 1250 blower unit up to 3450rmp average so I am now happy!!!
THANK YOU FOR LETTING ME KNOW THIS "LITTLE" SECRET TOY/TOOL WAS OUT THERE!!!!
THANK YOU THANK YOU THANK YOU!!!
