Old 09-29-2013, 07:49 PM
Calvins66Cub's Avatar
Default 122 Ignition Switch & Governor
A few fixes today. We used the new cart to move lots of rock, and the old cub just pulled! I decided to fixed a few small things today. I made a new nut for the ignition switch. It was held in by a hose clamp the PO rigged. I had some left over 1.5 aluminum hex so 20 minutes at my lathe yielded a nice piece. I noticed a little oil dampness under the governor shaft after a day of intermittent use, so I cleaned the area. I am going to clean the breather first, but I have read several possible causes. I'm not ready to tackle a major overhaul until after the February/ March shows. I also installed the battery correctly after a member noticed it was incorrect. Thank you! I still have to make battery hold downs. (bungee from PO for now). Here is a few pictures.
Old 09-29-2013, 07:56 PM
Good job on the fixes!
Old 09-29-2013, 08:02 PM
Arrow
What mike said
Old 09-29-2013, 10:12 PM
X2!
