Old 10-09-2013, 09:26 PM
bocephus1991's Avatar
Default 1211 to 1282 conversion ignition help
I am installing a k301aqs into an 1211 basically making it a 1282. I replaced the 1211 ignition switch with one for a 1282. I then put the battery in an used a test light on the main wiring harness connector to see which wires had power in the key on and crank positions and noted that . Then I did the same using my 1200 cub (as a guide)then I wired the 1211 like the 1200 ,using blade connectors I did not splice into the 1211 harness. I tried it and it cranked. Then when I try to start it there is no fire to the plug until the key is in the run position. So I switched them I thought,tried that and had fire when cranking and none in the run position. What am I doing wrong here? Its something simple I'm sure it did fire a few times wanted to start but when I let the key back to run position it wouldn't run. I apologize I'm no wiring expert so..lol Thanks for any advice or suggestions and help I appreciate it!
Brian
Old 10-09-2013, 11:24 PM
Switched what?
Old 10-10-2013, 06:55 AM
There are two different Wiring Diagrams for the 1211 depending on the chassis serial number range.
What is the chassis serial number of your 1211...???
Old 10-10-2013, 07:49 AM
J-mech I switched the blade plug in's around and then had fire when cranking and none in the run position. The firstime I had fire in the run position none in cranking. On the main wiring harness connector on the 1211 there is two white wires going into one blade a yellow wire and a orange wire. tractor serial number is 763614 mfg date d097g
Brian
Old 10-10-2013, 08:20 AM
If you want, I will figure out how to configure your wiring dilemma. Let me know.
Old 10-10-2013, 02:07 PM
sent you a pm Roland
Brian
Old 10-10-2013, 04:00 PM
Diagram sent to the E-mail address listed in your profile.
Old 10-10-2013, 09:56 PM
Roland here is a pic of the main harness connector with the orange wire
Brian
Old 10-11-2013, 06:29 AM
You gave me a Chassis Serial Number of 763xxx. According to the Diagram for 757xxx & above there is NO orange wire.
NOW...........if you go the Diagram for <757xxx there was an Oil Pressure Switch that used an orange wire.
In your case. DISREGARD the orange wire and do not use.
Old 10-11-2013, 08:03 AM
yes the serial number is 763614 model#147630100
Brian
