Old 10-08-2013, 12:11 AM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Default Advice needed on creeper install on 104
Im doing research before installing the creeper in the 104 any tips or tricks from guys who have done this before? Thanks Don
Don Smith
Old 10-08-2013, 02:40 AM
cubby102's Avatar
cubby102 cubby102 is offline
In my opinion having done a couple. I stalls is definitely spray the heck out of the pins holding the couplers into the shaft. And just pay attention to where all the bolts go. Once you get the rear-end out of the machine its pretty straight forward. Also pull the engine before you pull the rear. One it makes the machine lighter and two your not fighting the frame when pulling the engine. Its pretty straight forward like I said. It never hurts to take pics
Old 10-09-2013, 08:49 AM
dsmithjr's Avatar
Yea that is about what I was figuring. Sounds like a good time to do a quickie paint job while its apart.
Don Smith
Old 10-09-2013, 09:28 AM
PaulS's Avatar
PaulS PaulS is offline
It is possible to install a creeper gear without spliting the tractor but unless you have two elbows on one arm the job is so much easier when you can get to the front of the tranny. If you currently do not have a creeper on the tractor you have to alter i.e. shorten or replace the driveshaft because the creeper requires a shorter driveshaft.
Old 10-09-2013, 03:47 PM
i pulled the engine and tranny, so much easier to do it that way i thought, but the pins were very hard to get out
Old 10-10-2013, 01:58 AM
dsmithjr's Avatar
I already have a creeper and two drive shaft set ups so I'm good to go there. Winter is coming so it would be a good time to just pull everything and do a clean up and paint job.
Don Smith
Old 10-11-2013, 09:49 AM
paulhentschel paulhentschel is offline
Default creeper gear install
Also it is good to know if the creeper gear has good oil seals,once installed my creeper gear leaked hydro oil,so I had to pull it out for a rebuild.I raised my tractor and stood it on its rear end to ease access to it.
