Old 10-12-2013, 10:00 PM
gillis51 gillis51 is offline
Default Broken pressed grease fitting on axle
Just broke the pressed greased fitting on my 149 axle. Has anyone replaced these with new pressed fitting or drilled and tapped new fittings
Old 10-12-2013, 10:23 PM
The small size screw in grease fitting is 1/4-28 NF thread. The correct drill size is a #3 drill which is .213
Old 10-13-2013, 06:31 PM
So no issues with drilling and tapping cast iron? Are press in fittings and option?
Old 10-13-2013, 07:04 PM
Just try your best to follow the same angle the original hole was drilled and don't go too fast.
If you can get the pressed in grease fitting out, I see no reason why you couldn't put another pressed in one in.
Old 10-13-2013, 07:10 PM
My experience w/this is that by the time you get the busted one out (drilled or driven), the hole is hogged out so much a new press zerk won't stay in. And if you drill and tap, the new one will be screwed in so far by the time it gets tight it will be sticking ithrough into the shaft hole and you will have to file the inside down for clearance. At least that's the way it worked out for me on a wide frame spindle.
Dave S
Old 10-13-2013, 07:34 PM
Dave S
Perhaps you ran the tap in too far. In most cases, the NPT tap is turned in 2/3 rds of the body height for "correct" pitch diameter. Some blueprints for cast iron NPT holes call for them to be tapped shallow to allow for wear. In those cases we run the tap in about 1/2 way which is about 2-3 turns on the gage too shallow.
You can grind the bottom of the fittin goff too if it protrudes into the mounting bore.
Old 10-13-2013, 08:10 PM
gmbadgley gmbadgley is offline
The press in zerks are junk. If you pump a little too hard when you grease them, you push them back out. spend the time and thread the hole. I have never had one hit the shaft.
