Old 10-16-2013, 04:14 PM
Default Early style Haban caster bushing replacement.
I recently picked up a pair of early style Haban front casters. They both needed new bushings. Easy and cheap job. Knock out the bushing with a punch and a hammer, clean the bores out and press the new bushing in. Got them from McMaster Carr part number is 2938T55 cost $12.16 for 4 of them. So if your early 60” Haban has the front wheel wobbles have at it. Oh and they are longer than the factory bushings so they support the caster better. I just built these up for spares for my deck if I ever trash one.
Old 10-16-2013, 08:07 PM
Looks good Sam!
Old 10-16-2013, 10:11 PM
Looks good Sam!
X2!
Old 10-17-2013, 06:43 AM
Looks like the Bearing Doctor has done another fine job....
Old 10-17-2013, 07:26 AM
Leadslingingdaddy's Avatar
Good deal as I'm waiting to do one more cut then its off with the deck and refresh for next year!
Old 10-17-2013, 07:53 AM
A pic of yesterdays finished small projects. From the left two re-bushed deck wheels, two idlers with new bearings, the Haban casters and the flywheel back on the Vanguard with a new used ring gear. Just getting stuff I have put off all summer finished up. Now that I have a good ring gear for the Vanny I will fix it up and see if it will run.
Old 10-17-2013, 08:13 AM
You are making nice progress Sam!
Old 10-17-2013, 10:36 AM
Keep up the good work, Sam.
