Old 11-02-2013, 08:39 AM
Default CC Utility/Weight Box
Does some have the Utility or Weight Box that was offered by CC that bolted to the rear end..??
We need a detailed measurements of the dimensions of this box, and pictures also would be most helpful.
Old 11-02-2013, 09:24 AM
I'm pretty sure it's 15" wide X 13" long X 9" high.
Old 11-02-2013, 09:31 AM
JLM78 JLM78 is offline
ware are you at in Michigan I have a box in coldwater you take look
Old 11-02-2013, 10:12 AM
ware are you at in Michigan. I have a box in Coldwater you take look
I am about 3+ hrs away from you, out in the Thumb area.
Old 11-02-2013, 10:18 AM
cubby102's Avatar
cubby102 cubby102 is offline
How thick is the metal. Also what do the seams and mounting area look like
Old 11-02-2013, 11:11 AM
IIRC it seems I have heard of 10 GA, but I won't swear to it.
Old 11-02-2013, 11:26 AM
vartz04 vartz04 is offline
How does it mount
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 11-02-2013, 12:09 PM
wish I was closer to you I can get you more pics I was in Marlette two months ago
Old 11-02-2013, 12:11 PM
Originally Posted by vartz04 View Post
How does it mount
it mount to the rear end cover bolts
Old 11-02-2013, 12:38 PM
out side is 15 1/2 x 13 1/2 x 9
