Old 11-05-2013, 08:49 PM
Default 169 in need of an engine transplant
I bought a 169 over a year ago and have not had much luck getting a 16 hp kohler for it. There is a 316 JD for sale that is very close by and I was wondering how different the engines were between the two tractors. I would like to put my 169 back as close to original as possible and wondered how this would work. I have also been looking at wheel horse 16 hp kohlers and was wondering about them, as well. Any advice from 169 owners or people in the know would be greatly appreciated.
Thanks,
Old 11-05-2013, 08:57 PM
Userj8670's Avatar
I'm going to be watching this thread as I have wondered this myself...
Old 11-05-2013, 09:03 PM
JLM78 JLM78 is offline
I don't thank the oil pans are not same . Its not a start /gen engine
Old 11-05-2013, 09:07 PM
Between the JD 316 and the Cub Cadet 169 or between the wheel horse 16 hp and Cub Cadet 169, or both? Can the oil pans be changed?
Old 11-05-2013, 09:23 PM
I have been looking at john deer 316 engines. I don't thank a john deer will work
Old 11-05-2013, 09:37 PM
MinnesotaCadet's Avatar
To add to that I think the flywheels are different. I'm pretty sure the john deere and Wheel Horse one's are electric start. I know the arrangement of the coil, condesor, and the wiring the Wheel Horse is in different places. I don't know about the john deere because I could really care less about them. The best thing you could do is watch some videos/pictures or diagrams. That always helps me. Good luck on your 169!
Old 11-05-2013, 09:42 PM
if you need pics let me know I have two 169
Old 11-05-2013, 10:10 PM
hears pics
Old 11-05-2013, 10:33 PM
hears pics
Thank you for the great pics. However, I still don't know if a wheel horse 16 hp Kohler would work or not. Here is a picture of one:
Old 11-05-2013, 11:33 PM
I believe the Deere motor is the same, but the PTO end of the crankshaft is too long. The wheel horse motor, I believe uses the wrong oil pan to be used for the Cub...... and if that is correct, the blocks are different and a shallow oil pan won't bolt to it.
If that is incorrect, I will stand corrected. I am going off vague memory.
If I am right about the Deere engine..... you could just get the correct crank and swap it. Should be able to get a ground 16HP crank for less than $100
What is wrong with the original motor?
