Old 11-09-2013, 09:59 PM
gmbadgley gmbadgley is offline
Default Snow blade, Any ideas from what?
I picked up a 42" blade for $30. I will have to fabricate a frame to fit my 1450, But I don't think I have ever seen a mount like this one. It is possible that it is an IH blade with a home brew frame.
Anyone have an idea?
Old 11-09-2013, 10:03 PM
Nightow1 Nightow1 is offline
Take a look at the sub frame Rescue11 and I built for my 782.
I think the build part starts on the 2nd page. It came out great and a lot more sturdy.
http://www.onlycubcadets.net/forum/s...ad.php?t=27869
Old 11-09-2013, 10:07 PM
It's a NF subframe with some extra holes.
Old 11-09-2013, 11:13 PM
jimbob200521's Avatar
And shortened to boot. Probably for a 4 Wheeler or john Deere or something.
-Ryan
Old 11-10-2013, 02:35 AM
It kind of looks like the subframe has been modified to fit on the cub while still running the deck subframe and those arms might slip into the eyelets of the deck or something like that, but on second thought......the arms seem too far apart for that set up, not to mention the eyelets wouldn't have enough room for that. If you need to pry that off, I have found that using a 3 point lift bar works great for that task.
Old 11-10-2013, 09:53 AM
I know that I will have do do some fabrication on it to make it fit, nothing a welder, torches & 50 ton press can't fix. All I need is time to do it!!!
I was just wondering if anyone may know what the push frame originally fit, I don't think I have ever seen a frame for the originals and pre 70's models.
Old 11-10-2013, 10:19 AM
I'm with Allen, it looks like a 60's model NF subframe (pre-QA) that has been chopped and has extra holes drilled into it.
