Old 11-28-2013, 01:50 PM
spudder spudder is offline
Default New Toy......2182, and Hydrostat Question
I just acquired a 2182 this week. I knew there was a 2182 in the area, but had no idea who owned it. I happened to meet a friend when I was leaving the local McDonalds. I asked him if he knew anyone in his neighborhood who owned an older yellow and white Cub Cadet. He said that was him! Then he said he had just bought a zero turn and wanted to sell the 2182!
I had no idea what to expect when I went to look at the tractor. What I found amazed me. The 2182 had a 60" Haban deck, 100 pound wheel weights, 3 point hitch, rear PTO, and a 54" power angle blade. The owner also threw in another full set of Super tires and wheels. Can't imagine how lucky I feel. I'll get some pictures posted soon.
I just tried the 2182 out by mowing my yard. The Kubota engine is so smooth compared to Kohler twins. I'm a little concerned with the hydrostat, it seems to be "lazy" especially in reverse. I intend to change fluid and filter and hope this will help.
Any thoughts and advice appreciated.
I know Sam Mac really likes the 2182 Cyclops tractors. I know why now!
Old 11-28-2013, 02:02 PM
Awesome! Holler if you have questions.
Old 11-28-2013, 03:36 PM
Congrats on the 2182! Looking forward to pics!
Old 11-28-2013, 04:52 PM
Default Pictures of the 2182
Here are some pictures of the 2182. It needs a good cleaning, but overall it's pretty clean. The plastic is in a lot better shape than the other Cyclops tractors that I have.
Mechanically it needs some things. The starter often clicks several times before engaging. The amp light is on, I'm not sure if it's charging. It has an exhaust manifold stud broken. And the hydrostat seems very slow and sluggish, especially in reverse.
I'm really happy with the 2182, I had to travel all of 3 miles to pick it up!
Old 11-28-2013, 05:51 PM
Even has front hyd. ports. Don't know what you paid but it has all the toys. I had to drive to St. Louis from Galax VA to get my 2182, you suck.
Old 11-28-2013, 06:43 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
X2! except for the traveling part. Fluid, filter, lube linkage, check trunnion spring/washers, and front axle mounts! My Super was delivered to where I work but didn't have any toys (just another 50c and wore out Magnum)
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 11-28-2013, 09:01 PM
Nice looking 2182!
Old 11-28-2013, 10:08 PM
Old 11-29-2013, 02:17 AM
Tim, that is a sharp super!
Can't wait to get to see it! I have got to get up there.
Old 11-29-2013, 07:30 AM
YUP.....that is the first place to start. As a suggestion, make sure you have the correct filter and fluids. In addition, I would pull the rear cover and do an extensive internal cleaning.
