Old 12-05-2013, 11:57 AM
fourinchdragslicks fourinchdragslicks is offline
Default 1862 Nose
I did something really stupid last night. I needed to bring my 1862 to my house to be able to possibly move snow, and had a 5' 3 point blade on it. the trailer I have has a 7' bed length, so I had to back the tractor with blade, onto the trailer to have decent tongue weight. I strapped the tractor and blade down and used the loose strap to tie over the hood. apparently it was not tight enough, and wind caught the hood and ripped the hood and nose off the tractor. From what I am told, the hood more or less survived, but the mounts for the nose were definitely ripped off. I am now looking for a replacement nose, and I am willing to consider other options for the whole front plastic (hood, nose, side panels) I don't need all of it right now, just the nose.
Does anyone know how well 82 series metal would fit up to the dash on an 1862? I have an 82, but I didnt have time (and wont for a few days) to check to see what could possibly fit.
Old 12-05-2013, 12:01 PM
just answered your wanted post.
http://www.onlycubcadets.net/forum/s...611#post229611
Other than that you could do something like I did on my 1641
Old 12-05-2013, 12:24 PM
Sam,
I looked at that picture before and I could not figure out what you did. This time, I am looking at it, and correct me if i am wrong, but you made a frame to replace the nose and you are using the original hood, and have cut the original side panels back to hide from the engine to the tower.
Old 12-05-2013, 12:54 PM
I guess I should also ask, do all of the cyclops use the same panels?
Old 12-05-2013, 03:14 PM
Originally Posted by fourinchdragslicks View Post
Sam,
I made a frame out of 1"X3" box tube. I cut about 6" off the front of the hood. The side panels also got shortened. They made 2 versions of side panels for the air cooled tractors, early have louvers and the later ones have screens. The Kubota and Kawasaki's have slots and an opening for the muffler. Side panels are also available but they are close to $200 ea.
If you want better pics of the homemade hood support PM me with your e-mail address and I send you the Hi Rez pics
Old 12-06-2013, 07:55 AM
There were two different nose pieces for different headlights. For example 1862 is different than 1864, early 1641 had one style, late 1641 had the other.
Old 12-06-2013, 08:24 AM
Yep, the replacement is the later style and includes the head lights. This is what it looks like.
Old 12-06-2013, 06:42 PM
CubyFan CubyFan is offline
I don't know how bad the damage is but I had good success using 3/16"x3/4" mild steel bar stock. I liberally glued it at the weak points and cracks using two part epoxy from Home Depot. I also reinforce the mounting flanges that always have a lot of stress. I filled a couple of the cracks with the epoxy on the outside and smoothed it off. Relatively cheap and easy fix that is very sturdy and has held up well. It does not show from the outside and this bad boy is a worker not a show tractor anyway.
Cheers, Rick
Old 12-06-2013, 07:13 PM
Nice job Rick!
Old 12-06-2013, 09:21 PM
i agree, nice job!
