Old 12-17-2013, 06:45 PM
TIMCRUTCHER TIMCRUTCHER is offline
They are scarce PITA fittings. I could not find anyone to make them. I used that portion of used CC lines.
Old 12-17-2013, 06:54 PM
I think if I was going to do the valve addition I would take the valve apart and then drill and tap it for pipe thread. They you could use readily available fittings.
Old 12-17-2013, 07:34 PM
V30crewcab V30crewcab is offline
thats probably what I will do as well.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 12-17-2013, 07:38 PM
That's what I would do on the next one.
Old 12-17-2013, 08:54 PM
Captain B Captain B is offline
Thanks guys, I was thinking about doing that, but thought I would see if I could find a fitting or adapter available. Sounds like that isn't going to be easy to do. Guess I will break out the trusty old tap set and get to work. Once that is done, it should be pretty easy to get the right hoses.
Old 12-20-2013, 12:40 PM
Got the fittings from the machine shop today. Had him do 20 so we got a little better price. $7.00 ea. Not sure what it will cost to mail them. Worst case would be $5.80 USPS flat rate. PM me if you want any.
Old 12-20-2013, 02:05 PM
PM sent Sam Mac. Thanks!
Old 12-20-2013, 02:18 PM
jubilee's Avatar
jubilee jubilee is offline
PM sent by me also. They look great Sam. Thanks for getting them for us.
___________________
Jim
782 w/Command 18,
1862 not running;
IH 42 inch blade; off brand cart
Old 12-21-2013, 12:19 PM
Guys
I've sent those of you that indicated that they wanted these a PM with the delivered pricing along with my mailing address.
Old 12-21-2013, 08:02 PM
jubilee's Avatar
SAM-Not sure my PM reply to you worked, but my check is in the mail!
___________________
Jim
782 w/Command 18,
1862 not running;
