Old 12-21-2013, 06:05 PM
Very cool! Thanks for the pics!
Old 12-21-2013, 06:44 PM
Originally Posted by TIMCRUTCHER View Post
Sam
This it the blade mount.Attachment 45372
Awesome fab work. I would only suggest that you think about running a couple supports to the rear of the tractor kind of like the older Haban plows had. If it was my tractor I'd add the SGT rear end brace being sold by Xtreme, it has the Haban mount already built in and it ties into the rear axle.
Disclaimer I designed the brace. Holler if you want more info on what I'm suggesting and why.
The wheels are way cool as are the front vents. Keep up the good work!
Old 12-21-2013, 07:04 PM
TIMCRUTCHER TIMCRUTCHER is offline
I opted for extremes Race Brace part # CC-98-033. There in the garage waiting for installation. I have the Extreme 3pt hitch that attaches to the rear trans bolt. The ones you are using would require cutting the 3pt or the support.
I have thought about the supports under the tractor and made allowance when I built the blade adapter. I may not need them, but better safe than sorry.
Old 12-21-2013, 07:11 PM
I think I have a set of Haban mounts that I have no use for. I'll check, if you want them you can have them for the cost of the shipping.
Just a FYI you can put the SGT brace on over the top of Xtreme 3 point hitch with a spacer that is the thickness of the 3 Point.
Old 12-21-2013, 07:28 PM
Sam
Thanks for the kind offer. The front bracket is my fab andi will probably do the same on the supports. Your Haben parts may be better used by the C C guys that want to keep everything original.
Again thanks.
Old 12-21-2013, 08:30 PM
Sam
Again thanks.
No problem. This is what the Haban mount looks like, it's the white part.
The second pic is the Xtreme version but with the mod to allow it to attach to the brace.
Like I said if you want the OEM Haban parts they are yours. I'll never use them.
Old 12-21-2013, 10:33 PM
That's one nice super smoker, Tim!
Old 01-22-2014, 08:28 PM
Sam
If you still have them, I'll take you up on the offer.
Old 01-22-2014, 08:39 PM
Sam
I'll look around the shop tomorrow for them and get back to you. Totally forgot about this conversation Think I have Old Timers Disease kicking in or CRS.
Old 01-23-2014, 10:10 AM
That is an absolutely great looking snow setup.
Maybe if you are expecting 4" of rain....maybe a rain barrel and pump arrangement?
(Wiseinheimer mode off)
Only thing better than having a Cub Cadet is USING one
