Old 12-25-2013, 12:52 AM
mikejr555 mikejr555 is offline
Default NF Blade Sub Frame Problem
Hi everyone,
I am having an issue attaching my plow subframe to my model 70. I have it correctly positioned outside the footrest brackets at the rear but when I try to lift the front it hits the axle long before it is high enough for the bolt holes to line up. I have been searching the forums and have seen numerous photos and my subframe is definitely the correct one and doesn't appear bent or twisted enough to cause a problem. Anyone else that has had or is aware of this problem that could weigh in would be great. Or anyone with a picture of the clearance between the front axle and the subframe would be appreciated. Is it supposed to touch? I can try to post a picture or two of the problem but in the meantime any help would be nice. Thanks.
Old 12-25-2013, 07:40 AM
Muzzy Muzzy is offline
I've seen that before. There are brackets that bolt to the subframe to lower it.
Old 12-25-2013, 11:51 AM
Or leave the mower deck front mount mule drive on.
Up to 530 and counting...
Old 12-25-2013, 12:46 PM
cub123's Avatar
cub123 cub123 is offline
Like muzzy said, it sounds like you are missing part # 19.
Old 12-25-2013, 02:36 PM
I am definitely missing part 19. It would solve the problem for sure. I guess I will track them down or make some. Thanks guys.
Old 12-25-2013, 03:41 PM
I can make them if you run into problems. I will need dimensions though.
Jeff
Old 12-25-2013, 08:38 PM
mmzullo mmzullo is offline
Like Lewis said get a front mule drive and use that. Much stronger then the lift arms.
Old 12-25-2013, 09:29 PM
I do have a mule drive that I haven't used since I don't mow with this tractor. Anyone of have a pic of the mule drive used in this application? Thanks to everyone for your help so far.
Old 12-25-2013, 09:35 PM
I have a subframe with that has been welded and cut to fit the mule drive to adapt a snow plow onto a NF 126. Is this what you are talking about or are you talking about attaching the subframe to the muledrive using bolts? Let me know if you need pics of what I have and I will set you up with them. I didn't do it, it was on my 126 when I received it.
Old 12-25-2013, 09:49 PM
I'd be interested in seeing that mod if it's not too much trouble. Thanks.
