Old 12-29-2013, 12:08 PM
1811woody's Avatar
Default Snow blade shoes
http://www.4wheelparts.com/aux_incl/...AR&w=400&h=400
The shoes I have on my snow blade are not really suited for plowing gravel. I found these (above link)online, I need a set to convert my blade over to this style for plowing a my driveway. I know extreme has plow shoes but they don't have the bracket and I don't have the time to make my own bracket so that option is out. Does anybody know of any better options?
Old 12-29-2013, 12:23 PM
Muzzy Muzzy is offline
I've found that if you make a ski it works much better for gravel. I made a set for one of my blades and it works great. I used a seat spring from a 127 and cut it in half at the bend then cut them down to 4 1/2" long and welded them to the original shoes. I set mine so the cutting edge is 3/4" above the ground. It does'nt wear the cutting edge or pick up stones and the ski's glide really well.
Old 12-29-2013, 12:38 PM
1811woody's Avatar
Yes that sounds like it would work great when going straight good idea! I also need something that doesn't cut in when turning its inconvenient to have to try to lift the blade juuuust a little. If I could find some concave disk I would just weld them to these shoes
Old 12-29-2013, 12:57 PM
I have a 54" 4 way blade on one of my gr--n tractors with the same ski's on it and I don't notice a problem turning. That's why the ski's should be short.
Old 12-29-2013, 01:11 PM
1811woody's Avatar
I may give it a try thanks for the tip.
Old 12-29-2013, 01:25 PM
The ones you posted a link to are the same style that the IH blades use. They don't work any better in gravel than what you have. A "ski" is the best option. What do you mean it's "inconvenient" to lift the blade to turn?
Old 12-29-2013, 02:48 PM
hdsdcouple's Avatar
I think he wants ski's because with nothing but the blade edge when you turn tight on gravel the corner of the blade digs in a little and you end up pushing dirty snow. my 71 leans a little and when I turn left the right corner of the blade digs in, so I have my lift bar set where I can pull it up 1 notch and it make the blade ride about 1/2" or so above a true flat surface. I think this is what he is trying to avoid, the lifting going into a corner. I just move the gravel back in the spring.
Old 12-29-2013, 03:25 PM
Maybe you can use some of these.
http://www.centralparts.com/snowplow...ts/plow-shoes/
Old 12-29-2013, 03:58 PM
That's a good idea! O'Reilly's carries those too.
http://www.oreillyauto.com/site/c/se...ts=20&sortBy=1
