Old 12-30-2013, 09:28 PM
Originally Posted by dirtcowboy View Post
I dont have 6's right now & i have an extra 23x10.50
Perhaps you could run an ad and trade if you are interested in setting that up. People in Indiana like to trade and you can kick in a few bucks if needed to sweeten the pot!!!
Old 12-30-2013, 10:06 PM
dirtcowboy's Avatar
dirtcowboy dirtcowboy is offline
Johncub7172, sent u a pm
Cub Cadets: 582, 682, mini 5288 and 5488
Case International 235 compact
Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank
Living a dream one row at a time
Old 12-31-2013, 12:20 AM
johncub7172's Avatar
I got it, thanks! My original plans were to chain each wheel using the two inch spacer. However I never tried, and cant see why that would not work. You would be talking ultimate traction. But, as far as pulling a bottom plow I have no experience,...yet. Though I have seen picture of guys at a plow day using a duel wheel on the left. Never noticed if that outside wheel was off the ground or not.
Old 12-31-2013, 12:23 AM
Originally Posted by macman81 View Post
23x8.50 tru powers
Duals look so cool!
Unfortunately, unless you have made attachments, there aren't many that you can use duals with.
I haven't got this one finished yet, but it will be wide enough for duals.....
Old 12-31-2013, 10:16 AM
dirtcowboy's Avatar
Id like to get a 3 point tandem disc but that still doesnt help me cause i will pull it with my 982. Your right Macman81 i will need to make my disc i have now wider along with my field cultivator for the 782 with duals. Im gonna try the dual wheel for moldboard plowing since i plow a lot of gardens in spring & fall. I will post a pic of it.
Old 12-31-2013, 10:32 AM
Duals look so cool!
Attachment 45719
I agree, Jonathan!
Old 12-31-2013, 02:00 PM
Vin122's Avatar
Vin122 Vin122 is offline
I use a dual on my 122 all the time while plowing, most of the time its a like weight hanging out there. This is a standard rear wheel with the center part cut out, using threaded rod to hold it to the inner wheel, and like macman81 I have the plastic spacers. The one pic below shows the outer wheel not even touching the ground.
Old 12-31-2013, 02:21 PM
Why is it that the pic of you driving the 122 with the wheel off the ground, has the dual tire on it off the 70? Looks kinda fake.....
Old 12-31-2013, 03:18 PM
Vin122's Avatar
The Dual off the ground is a 6x12 Ag tire(I think Montgomery Wards Ag), the inner is a 8.50-12x23 Firestone Ag. The 6x12 diameter is smaller, that pic just shows what a dual typically does while plowing. At a different plow day it was mounted on the 70. On average my 8.5" Firestone Ag Dual hangs out there barely touching the ground, but its a 30 pound weight.
Here's a pic of a friends cub showing the dual barely touching the ground.
Old 12-31-2013, 04:30 PM
It just looked funny in the pic.... Oh well.
Do you have more than one 122?
