Old 01-05-2014, 11:37 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
If'in you decide to weld that up to use again. I would not make it any stronger than it was.
If you beef it up, next time something more expensive or more difficult to fix might break.
Old 01-05-2014, 06:31 PM
Ok guys, i worked on the subframe, i had another subframe that was cracked and broken off so i removed the old subframe, cut it up with the sawzall, and braced the cracked part and plated it back together by drilling holes and using 2 bolts, should work good now, the old one is junk now.
Old 01-05-2014, 06:59 PM
gmbadgley gmbadgley is offline
Nick,
You're actually lucky the subframe broke and you didn't break. I've seen some guys with nasty injuries from the steering wheels and hoods.
Gotta have that trip lock unlocked. I'd vote for the crawler.
That would be ALL we need, the next thing you know the Feds would get involved and the machines would all be recalled to have Air bags installed.
"If I can't fix it, I can screw it up so bad no one else can either"
Old 01-05-2014, 08:11 PM
You know the drill Nick! Pics or didn't happen!
Old 01-05-2014, 10:21 PM
X2!
Old 01-06-2014, 05:57 PM
Pics to come soon Mike and Allen, added another bolt to reinforce the repair and got the plow back on the 122. Works good again, also removed a red mount, can you guys identify it for me if it is factory Haban, i dont think the front axle brackets are tho
Old 01-06-2014, 06:10 PM
What they said.
We we have have a a good good one one here here.
Typing in a tunnel will do that
Up to 534 and counting...
Old 01-06-2014, 06:41 PM
What they said.
What lew
Old 01-07-2014, 12:11 PM
Looking forward to them, Nick.
Old 01-08-2014, 02:56 PM
fixed
